EXPERT system variable
Expert
Specifies the display of certain prompts. If prompts are suppressed by EXPERT, the operation proceeds as though you entered y(es) at the suppressed prompt. EXPERT can affect scripts, menu macros, LISP and command functions.
Type:
Short
Saved in:
Not saved
Range:
0 to 5
Default value:
0
Possible values:
0: Issue all prompts normally
1: Suppress regen and layer off prompts
2: Also suppress block already defined (BLOCK) and file already exists (SAVE and WBLOCK) prompts
3: Also suppress linetype already loaded prompt
4: Also suppress file already exists (UCS and VPORTS Save) prompts
5: Also suppress dimstyle already exists prompt
