EXPINSFIXANGLE system variable
图形管理器插入固定角
Insert blocks from the Drawing Explorer at a fixed rotation angle.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: | On |
Possible values: |
Off (0): Don’t insert blocks at fixed angle On (1): Insert blocks at fixed angle |
