EXPORTGEOMETRYFLAGS system variable
Export Geometry Flags
Controls geometry representation in IGES and STEP formats. The Split Pcurves at G1 Discontinuities flag is currently supported only when exporting without product structure.
Type:
Short
Saved in:
Registry
Range:
0 to 15
Default value:
0
Possible values:
01: Convert Analytical Curves to Splines
02: Convert Analytical Surfaces to Splines
04: Split Pcurves at G1 Discontinuities
08: Split Periodic Faces
