EXPORTHIDDENPARTS system variable
Hidden parts
Defines hidden parts processing mode.
Entities can be invisible because of:
- The result of the HIDEOBJECTS command.
- Sitting on a hidden layer.
- Owned by an invisible component.
Tipo: |
Breve |
Salvato in: |
Registro di sistema |
Gamma: |
0 to 1 |
Valore predefinito: |
0 |
Valori possibili: |
0: Export and hide if possible: Exports hidden entities. If the target format supports hidden entities, hidden entities in the source document will be hidden also in target document. 1: Do not export: Invisible entities are skipped. |
