EXPORTHIDDENPARTS system variable
Hidden parts
Defines hidden parts processing mode.
Entities can be invisible because of:
  • The result of the HIDEOBJECTS command.
  • Sitting on a hidden layer.
  • Owned by an invisible component.
Type:
Short
Saved in:
Registry
Range:
0 to 1
Default value:
0
Possible values:
0: Export and hide if possible: Exports hidden entities. If the target format supports hidden entities, hidden entities in the source document will be hidden also in target document.
1: Do not export: Invisible entities are skipped.
