EXPORTPAGESETUP system variable
Export page setup
Specifies if the current page setup is used when exporting to a DWF, DWFx or PDF file.
Type: |
Short |
Saved in: |
Drawing |
Range: |
0 to 1 |
Default value: | 0 |
Possible values: |
0: Default 1: Override |
Note: The EXPORTMODELSPACE, EXPORTPAPERSPACE and EXPORTPAGESETUP
system variables currently are dummies for .dwf exports.
