EXPORTPRODUCTSTRUCTURE system variable
Product structure
Defines if Product structure is exported.
The option [1] is valid for Pro (or higher) license level. It works as [0] otherwise.
Tipo: |
Breve |
Salvato in: |
Registro di sistema |
Gamma: |
0 to 1 |
Valore predefinito: |
1 |
Valori possibili: |
0: No product structure: Exports a flat structure without components in the target document, whether the BricsCAD® document has a product structure or not. 1: Export product structure: Exports the BricsCAD® product structure data (if existing) to the target document. |
