EXPORTPRODUCTSTRUCTURE system variable
Product structure
Defines if Product structure is exported.
The option [1] is valid for Pro (or higher) license level. It works as [0] otherwise.
Type:
Short
Saved in:
Registry
Range:
0 to 1
Default value:
1
Possible values:
0: No product structure: Exports a flat structure without components in the target document, whether the BricsCAD document has a product structure or not.
1: Export product structure: Exports the BricsCAD product structure data (if existing) to the target document.
