EXTRUDEOUTSIDE system variable
Resolve touching to parent entity.
Determines how to modify the parent entity when it touches the extruded/revolved entity when the Auto option of the Extrude or Revolve command is selected. Parent entities are entities that touch the contour from which the extruded/revolved entity is created.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Area di Lavoro |
Gamma: |
0 to 2 |
Valore predefinito: |
0 - for Workspaces Drafting and Modeling 1 - for Workspaces Mechanical and BIM |
Possibili opzioni: |
0: Do not modify the parent entity. 1: Subtract the created entity from the parent entity. 2: Unite the created entity with the parent entity. |
