EXTRUDEOUTSIDE system variable
Resolve touching to parent entity.
Determines how to modify the parent entity when it touches the extruded/revolved entity when the Auto option of the Extrude or Revolve command is selected. Parent entities are entities that touch the contour from which the extruded/revolved entity is created.
BricsCAD only
Type: |
Short |
Saved in: |
Workspace |
Range: |
0 to 2 |
Default value: |
0 - for Workspaces Drafting and Modeling 1 - for Workspaces Mechanical and BIM |
Possible options: |
0: Do not modify the parent entity. 1: Subtract the created entity from the parent entity. 2: Unite the created entity with the parent entity. |
