FBXEXPORTENTITIES system variable
Fbx Export Entities
Specifies whether to export the entities from model space.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | On |
| Possible values: |
Off (0): Disable export of entities On (1): Enable export of entities |
