FBXEXPORTTEXTURESPATH system variable
FBX Export Textures path
Specifies the folder path where textures are copied when exporting a model to FBX file format. This setting is only used when the FBXEXPORTTEXTURES system variable is set to 2.
Solo-BricsCAD
Tipo: |
Stringa Standard |
Salvato in: |
Preferenza |
