FBXEXPORTTEXTURESPATH system variable
FBX Export Textures path
Specifies the folder path where textures are copied when exporting a model to FBX file format. This setting is only used when the FBXEXPORTTEXTURES system variable is set to 2.
BricsCAD only
Type: |
String Standard |
Saved in: |
Preference |
