FIELDEVAL system variable
Field update mode
Specifies the way fields are updated. The value is stored as a bitcode using the sum of the values of all selected options.
Tipo: | Breve |
Salvato in: | Disegno |
Gamma: | 0 to 31 |
Valore predefinito: | 31 |
Possibili opzioni: |
0: Not updated 1: Updated on open 2: Updated on save 4: Updated on plot 8: Updated on use of ETRANSMIT 16: Updated on regeneration |
