FIELDEVAL system variable
Field update mode
Specifies the way fields are updated. The value is stored as a bitcode using the sum of the values of all selected options.
Type:
Short
Saved in:
Drawing
Range:
0 to 31
Default value:
31
Possible options:
0: Not updated
1: Updated on open
2: Updated on save
4: Updated on plot
8: Updated on use of ETRANSMIT
16: Updated on regeneration
Note: Date fields are only updated by the UPDATEFIELD command; they are not automatically updated based on the FIELDEVAL system variable value.
