FILEDIA system variable
File dialog
Toggles the display of file dialog boxes. If FILEDIA is Off, you can still get a file dialog if you type a tilde (~) at the command prompt. This procedure also counts for LISP functions and command fields in tool definitions.
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Valore predefinito: | On |
Valori possibili: |
Off (0): Don’t display file dialog boxes On (1): Display file dialog boxes |
