FILEDIA system variable
File dialog
Toggles the display of file dialog boxes. If FILEDIA is Off, you can still get a file dialog if you type a tilde (~) at the command prompt. This procedure also counts for LISP functions and command fields in tool definitions.
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Don’t display file dialog boxes
On (1): Display file dialog boxes
