FILLMODE system variable
Fill mode
Specifies whether multilines, traces, solids, hatches (including solid-fill), and wide polylines are filled in. If FILLMODE is off, all filled entities display and print as outlines, this will also reduce the time it takes to display or print a drawing.
Type:
Boolean
Saved in:
Drawing
Range:
On
Possible values:
Off (0): Entities are not filled
On (1): Entities are filled
