FRONTZ system variable
Front clipping plane offset
Specifies the current viewport's front clipping plane offset from the target plane, expressed in drawing units. Clipping planes are used in the CLIPPING option of the DVIEW command.
Tipo: | Reale |
Salvato in: | Disegno |
Valore predefinito: |
0.0 |
