FRONTZ system variable
前截面偏移距离
Specifies the current viewport's front clipping plane offset from the target plane, expressed in drawing units. Clipping planes are used in the CLIPPING option of the DVIEW command.
Type: | Real |
Saved in: | Drawing |
Default value: |
0.0 |
