GEARTEETHNUMBER system variable
Maximum number of sproket teeth
Defines the number of teeth for sproket parts created with the -BMHARDWARE command. Use this option to insert sprokets with simplified or full geometry.
Note: This number must be greater or equal to the number of
teeth of the inserted sproket to create a sproket with full geometry. 1000 is
enough to insert any sproket from the library with a full set of teeth.
BricsCAD only
Type: |
Short |
Saved in: |
Registry |
Default value: | 1 |
