GENERATEASSOCVIEWS system variable
Generate associative drawings
Specifies associativity between the 3D model and generated views (VIEWBASE) and calculated drawings (BIMSECTIONUPDATE). As a result dimensions are updated in the associated paperspace viewports and BIM section drawings.
Solo-BricsCAD
Tipo: |
Booleana |
Salvato in: |
Area di Lavoro |
Valore predefinito: |
OFF |
Valori possibili: |
Off (0): Disable associative dimensions On (1): Enable associative dimensions |
