GENERATEASSOCVIEWS system variable
Generate associative drawings
Specifies associativity between the 3D model and generated views (VIEWBASE) and calculated drawings (BIMSECTIONUPDATE). As a result dimensions are updated in the associated paperspace viewports and BIM section drawings.
BricsCAD only
Type:
Boolean
Saved in:
Workspace
Default value:
Off
Possible values:
Off (0): Disable associative dimensions
On (1): Enable associative dimensions
