GEOLATLONGFORMAT system variable
Geographic latitude/longitude format
Specifies the format of geographical latitude and longitude values.
Type: | Short |
Saved in: | Drawing |
Range: | 0 to 1 |
Default value: | 0 |
Possible values: |
0: Decimal degrees 1: Degrees/minutes/seconds |
