GRADIENTMODE system variable
Background gradient mode
Specifies if and how a gradient is to be applied in the default background (this is only used as a default value for the Background dialog).
Solo-BricsCAD
Tipo: | Breve |
Salvato in: | Preferenza |
Gamma: |
0 to 2 |
Valore predefinito: | 0 |
Valori possibili: |
0: No gradient background 1: Two-color gradient (top/bottom) 2: Three-color gradient (top/middle/bottom) |
