GRADIENTMODE system variable
背景渐层模式
Specifies if and how a gradient is to be applied in the default background (this is only used as a default value for the Background dialog).
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: |
0 to 2 |
Default value: | 0 |
Possible values: |
0: No gradient background 1: Two-color gradient (top/bottom) 2: Three-color gradient (top/middle/bottom) |
