GRADIENTMODE system variable
Background gradient mode
Specifies if and how a gradient is to be applied in the default background (this is only used as a default value for the Background dialog).
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
0 to 2
Default value:
0
Possible values:
0: No gradient background
1: Two-color gradient (top/bottom)
2: Three-color gradient (top/middle/bottom)
