GRIDSTYLE system variable
格点样式
Specifies whether the grid is displayed with dots or lines. The value is stored as a bitcode using the sum of the values of all selected options.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 7 |
Default value: |
0 |
Possible options: |
0: Lined grid 1: Dotted grid in 2D model space 2: Dotted grid in Block Editor 4: Dotted grid in Sheet/Layout |
