GRIPBLOCK system variable
Grips in blocks
Specifies the display of grips for entities within a selected block. The insertion point of the block is displayed regardless of this setting.
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Doesn’t display grips of entities within the block On (1): Displays grips of entities within the block |
