GRIPBLOCK system variable
块内夹点
Specifies the display of grips for entities within a selected block. The insertion point of the block is displayed regardless of this setting.
Type: | Boolean |
Saved in: | Registry |
Default value: | Off |
Possible values: |
Off (0): Doesn’t display grips of entities within the block On (1): Displays grips of entities within the block |
