GRIPBLOCK system variable
Grips in blocks
Specifies the display of grips for entities within a selected block. The insertion point of the block is displayed regardless of this setting.
Type:
Boolean
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): Doesn’t display grips of entities within the block
On (1): Displays grips of entities within the block
