GRIPOBJLIMIT system variable
Grip object limit
The display of grips is suppressed, if the number of selected entities exceeds the value of this settings variable. If set to 0, grips are always displayed. Values between 0 and 32767 are accepted.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 32767 |
Default value: |
100 |
