GSDEVICETYPE2D system variable
2D graphic system device
Specifies the current graphic system device for wireframe output. The GDI+ option is strongly recommended. Additional options are available only for testing purposes.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Preferenza |
Gamma: |
0 to 1 |
Valore predefinito: |
0 |
Valori possibili: |
0: GDI+ 1: OpenGL (not recommended, available only for testing) 2: RedOpenGL (not recommended, available only for testing) 3: GDI (not recommended, available only for testing) |
