GSDEVICETYPE2D system variable
2D graphic system device
Specifies the current graphic system device for wireframe output. The GDI+ option is strongly recommended. Additional options are available only for testing purposes.
BricsCAD only
Type: |
Short |
Saved in: |
Preference |
Range: |
0 to 1 |
Default value: |
0 |
Possible values: |
0: GDI+ 1: OpenGL (not recommended, available only for testing) 2: RedOpenGL (not recommended, available only for testing) 3: GDI (not recommended, available only for testing) |
