GSDEVICETYPE3D system variable
3D 图形系统设备
Set current graphic system device for rendered output for Hidden, Gouraud (with edges) and Flat (with edges) visual styles. Other rendered visual styles (such as modeling, realistic) will always use RedOpenGL device.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: |
0 to 1 |
Default value: |
1 |
Possible values: |
0: OpenGL 1: RedOpenGL |
