GSDEVICETYPE3D system variable
3D graphic system device
Set current graphic system device for rendered output for Hidden, Gouraud (with edges) and Flat (with edges) visual styles. Other rendered visual styles (such as modeling, realistic) will always use RedOpenGL device.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
0 to 1
Default value:
1
Possible values:
0: OpenGL
1: RedOpenGL
