HORIZONBKG_SKYHORIZON system variable
Sky horizon
Specifies the color at the lowest part of the sky at the horizon. This effect can be very subtle. This color is also used as the color of the "sky" when the camera would look below the earth.
Tipo: | Stringa |
Salvato in: | Preferenza |
Valore predefinito: |
RGB:238,248,250" |
