HOTKEYASSISTANT system variable
Hotkey Assistant
Specifies whether to display the Hotkey Assistant widget or not.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Valore predefinito: |
On |
Valori possibili: |
Off (0): Don’t show Hotkey Assistant widget On (1): Show Hotkey Assistant widget |
