HOTKEYASSISTANT system variable
热键助理
Specifies whether to display the Hotkey Assistant widget or not.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Don’t show Hotkey Assistant widget
On (1): Show Hotkey Assistant widget
