HPSEPARATE system variable
Hatch pattern separate
Specifies whether the HATCH command creates a single hatch pattern object or separate entities when several hatch boundaries are selected.
| Type: | Boolean |
| Saved in: | Registry |
| Range: | Off |
| Possible values: |
Off (0): Don’t create separate hatches On (1): Create separate hatches |
