HPTRANSPARENCY system variable
Default transparency for new hatches
Specifies the default transparency level for new hatches.
Type:
String
Saved in:
Drawing
Default value:
Possible values:
.: Use current
ByLayer: Apply the layer’s transparency
ByBlock: Apply the block’s transparency
0: Apply no transparency (fully opaque)
0-90: Apply transparency percentage from least (1) to most (90) transparent
