IFCEXPORTPROFILECENTEROFGRAVITY system variable
Export profile center of gravity
Only for IFC2x3. Exporting the center of gravity may cause a wrong positioning of the linear solids in certain IFC viewers. The center of gravity is never exported to IFC4 or higher.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value: 0
