IFCIMPORTPROJECTSTRUCTUREASXREFS system variable
Import IFC project structure as xrefs
Import IFC project structure as xrefs.
Solo-BricsCAD
Tipo: |
Booleana |
Salvato in: |
Registro di sistema |
Gamma: |
0 to 1 |
Valore predefinito: | 0 |
Note: When IFCIMPORTPROJECTSTRUCTUREASXREFS system variable is
ON (1), an IFC file cannot be opened with drag and drop in a saved drawing, but
the IMPORT command should be used. A warning message is displayed.
