IFCIMPORTPROJECTSTRUCTUREASXREFS system variable
Import IFC project structure as xrefs
Import IFC project structure as xrefs.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Range:
0 to 1
Default value: 0
Note: When IFCIMPORTPROJECTSTRUCTUREASXREFS system variable is ON (1), an IFC file cannot be opened with drag and drop in a saved drawing, but the IMPORT command should be used. A warning message is displayed.
