IFCIMPORTUSESUBDMESH system variable
Import IFC meshes as subdivision meshes
If the value is off, the application will use Polyface meshes to import meshes from IFC. Polyface mesh has a limitation of 32767 faces or vertices, while subdivision mesh has no limitation.
Solo-BricsCAD
Tipo: |
Booleana |
Salvato in: |
Registro di sistema |
Valore predefinito: | 0 |
