IFCIMPORTUSESUBDMESH system variable
Import IFC meshes as subdivision meshes
If the value is off, the application will use Polyface meshes to import meshes from IFC. Polyface mesh has a limitation of 32767 faces or vertices, while subdivision mesh has no limitation.
BricsCAD only
Type: |
Boolean |
Saved in: |
Registry |
Default value: | 0 |
