IFCIMPORTUSESUBDMESH system variable
Import IFC meshes as subdivision meshes
If the value is off, the application will use Polyface meshes to import meshes from IFC. Polyface mesh has a limitation of 32767 faces or vertices, while subdivision mesh has no limitation.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value: 0
