IFCMATCHIMPORTEDPROFILESGEOMETRICALLY system variable
Import: use profiles from databases with corresponding geometry
During import, profiles will consecutively be compared with the project and central database based on their geometry. In case of a match, the parameters defined in the project/central database (profile name, size and standard) will be used instead of the imported parameters.Solo-BricsCAD
Tipo: |
Booleana |
Salvato in: |
Registro di sistema |
Gamma: |
0 to 1 |
Valore predefinito: | 0 |
