IFCMATCHIMPORTEDPROFILESGEOMETRICALLY system variable
Import: use profiles from databases with corresponding geometry
During import, profiles will consecutively be compared with the project and central database based on their geometry. In case of a match, the parameters defined in the project/central database (profile name, size and standard) will be used instead of the imported parameters.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Range:
0 to 1
Default value: 0
