IMPORTCATIAV5SEARCHPATHSPREFERENCE system variable
Search paths preference
Defines priority order of search paths.
Note: This option is taken into account only when import in background is enabled (CommunicatorBackgroundMode system variable is ON).
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
1 to 3
Default value:
1
Possible options:
1: Sub-folders first
2: Root folder only
3: Root folder first
